[Flow] Target endpoint for xxx can not be built!
Discussion in '3CX Phone System - General' started by Manouchehr, Jan 25, 2017.
  1. Manouchehr
    Jan 17, 2017
    28
    Hello all,
    I have a Cisco 504G ip phone in the branch office and it has registered with our 3CX server in the HQ... But i cannot have the calls flowing..... i have a VOIP account with my provider in place....
    Here is a log i saw
    01/25/2017 1:10:57 PM - [Flow] Target endpoint for xxxxxx can not be built!
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Manouchehr,
    Please enable the PBX Delivers Audio option on your extension and try to make a call to an extension in your lan, and let us know how that goes.
  3. Manouchehr
    Jan 17, 2017
    28
    Hi, thanks for the response. I connected another extension in the lan. and i can call between the extensions. but still no luck with calling to the outside number.
  4. Manouchehr
    Jan 17, 2017
    28
    Here is a log when i try to call to one of DIDs i assigned from my provider....
    01/25/2017 2:43:03 PM - Call to T:Line:10002>>004144xxxxxx@[Dev:sip:46.19.xx:5060] from L:12.1[Extn:105] failed, cause: Cause: 503 Transport failure: no transports left to try/INVITE from local
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    I assume you have an inbound rule in place that directs the call to that extension. so if you change that inbound rule to ring a different extension does it work?
    This will help us determine if the phone is to blame or not.
    Also you said "still no luck with calling to the outside number." and "Here is a log when i try to call to one of DIDs i assigned from my provider.."
    The first suggest your are making an outbound call. The second that you are making an inbound call.
    No calls work?
  6. Manouchehr
    Jan 17, 2017
    28
    ok, I corrected my inbound rules and have set outbound rules as well.......now when i make outgoing calls.... i get the following message "on the phone screen it is written "SessionProgess" then it changes to Temporarily unavailable.
    01/25/2017 2:57:54 PM - Call to T:Line:10003>>00414450xxx@[Dev:sip:94.102.x.x:5060] from L:26.1[Extn:105] failed, cause: Cause: 480 Temporarily Unavailable/INVITE from 94.102.x.x:5060
    And of course i tried the incoming calls too, but it does not work.
  7. Manouchehr
    Jan 17, 2017
    28
    Anyone please?
