FNB Talk
Discussion in '3CX Phone System - General' started by cyberkoos, Nov 9, 2012.
  1. cyberkoos
    Nov 9, 2012
    I have downloaded and succesfully installed 3CX phone system. I have configured 2 extensions and can make internal calls.
    I have a SIP trunk with FNB Talk (South Africa) and would like to know how to set it up with 3CX. I have set it up on Asterisk, which is a breaze. I cannot get it to work on 3CX.
    Any ideas?
    11,262
    358
    Even if there is not a template for a provider, in most cases, you should be able to use the Generic SIP trunk settings, and get it to work.
    What sort of errors are you getting?
    If you have set up a SIP trunks previously, then it should be fairly straight forward. The exception might be if your provider is using an unusual authentication scheme.
