Forbidden when using TLS
Discussion in '3CX Phone System - General' started by matt.meyers, Mar 13, 2014.
  1. matt.meyers
    Mar 13, 2014
    I have a remote extension that was setup using TLS. The phone registers fine, but when I try to call another internal extension, externally or a system extension such as echo I get the message that the incoming call was rejected and the caller is unknown.
    below is the log from the server.
    12-Mar-2014 21:28:53.102 Leg L:15.1[Unknown:] is terminated: Cause: BYE from PBX
    12-Mar-2014 21:28:53.052 [CM502001]: Source info: From: "Yealink T-46G"<sip:501@55.189.68.157:5061>;tag=729163406; To: <sip:*777@55.189.68.157:5061>
    12-Mar-2014 21:28:53.052 [CM503013]: Call(C:15): Incoming call rejected, caller is unknown; msg=Ivite-IN Recv Req INVITE from 24.242.74.6:21391 tid=682971438 Call-ID=1902435571@20.10.10.103:
    INVITE sip:*777@55.189.68.157:5061 SIP/2.0
    Via: SIP/2.0/TLS 20.10.10.103:21391;rport=21391;branch=z9hG4bK682971438;received=24.242.74.6
    Max-Forwards: 70
    Contact: <sip:501@20.10.10.103:21391;transport=TLS>
    Call-ID: 1902435571@20.10.10.103
    CSeq: 2 INVITE
    Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
    Content-Type: application/sdp
    Proxy-Authorization: Digest username="501",realm="3CXPhoneSystem",nonce="414d535c0931a8e499:843c9b759f78ddca5b77063cf900babb",uri="sip:*777@55.189.68.157:5061",response="ab03d4654741a056147fed80b2d71828",algorithm=MD5
    Supported: replaces
    User-Agent: Yealink SIP-T46G 28.71.0.176
    Allow-Events: talk, hold, conference, refer, check-sync
    Content-Length: 554
    v=0
    o=- 20000 20000 IN IP4 20.10.10.103
    s=SDP data
    c=IN IP4 20.10.10.103
    t=0 0
    m=audio 14000 RTP/AVP 0 8 9 18 101
    a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:M2UxZDEwMjQyM2M4ZDgwNTNkMGM5OGFmNDRkNGY0
    a=crypto:2 AES_CM_128_HMAC_SHA1_32 inline:MmM1ODhlMWQ1MTJkMTJmYjNmYTZkMjJlMjBhYmQz
    a=crypto:3 F8_128_HMAC_SHA1_80 inline:Nzg1NWZkMGM2M2QzYjA2YzIxMGQ5MDJlMjk1NGRh
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:9 G722/8000
    a=rtpmap:18 G729/8000
    a=fmtp:18 annexb=no
    a=fmtp:101 0-15
    a=rtpmap:101 telephone-event/8000
    a=ptime:20
    a=sendrecv
