Forbidden
Discussion in 'iOS' started by MiPo, Apr 2, 2013.
  1. MiPo
    Apr 2, 2013
    Anfängerfrage:
    Ich benutze Iphone mit App 1.1.5 und 3CX 11 Anlage. Tunnel verbindet sich ohne Probleme.
    Registrierung des Iphone kommt immer: Forbidden
    Einstellungen in der 3CX finde ich nichts, wo ich was freigeben kann.
    Danke
    11,123
    330
    I don't speak German, but from what I gather, your problem might be the option in the 3CX extension settings, is set to NOT allow outside registration. I'm not positive it the tunnel is being used or not. If it is then this should not be necessary.
