- Joined
- Mar 29, 2009
- Messages
- 7
- Reaction score
- 0
I have a 3CX phone system at a central point and at our remote offices we are using 3CX VOIP PHONES. Between the offices we have satellite communication with limited bandwith. There are no landlines here nor any fibers, satellite is teh only way. Everything is working fine but the system always use THE PCM codecs which takes to much bandwith for us. It is also a problemm with other internet usage at the same time as the line get slow. I want only to use the GSM codec if possible jsut for the 3CX phones which are at remote offices if not i want to force GSM codec on all clients. As GSM should not occupy more the 16 kbit it wouls suite as much better. I have tried to change the prority settings in 3CX phone but it is always PCM anyway .
I am searching for step by step instruction on how to force the 3CX system to just use the GSM codec . Maybe it is an RTFM but i have not managed to found it. GSM codec is stated on the homepage of 3CX that it should be included in the free version. If this is not correct, please tell me and i will buy the commersial version directly but i have to know all the facts. All your tecnichians out there, please help me out with this one.
Best regards
Toby
Best regards
Toby
