Force VM PIN Change
Discussion in 'Ideas' started by slsupport, Nov 16, 2015.
  1. slsupport
    Nov 16, 2015
    6
    Today on the PBX we cannot choose a option which forces a user to change his VM PIN on first logon.
    We should really have this option available to ease provisioning to a large number of users.
    Essentially we can issue everyone a default VM PIN.. and on first logon they are forced to change.
    Today there is no way to force a PIN change.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,552
    298
    I have in the past suggested an option where VM pins need to meet some complexity rules, that are configurable by the admin. It got rejected - something about the system already tells us which extensions ave WEAK pins.
    Folks for some reason think setting their PIN to 666 or their extension is good to do.
    I do not want to email them myself. I'd like the system to tell them the PIN doe not meet complexity requirements.
