Forced to use 3CX SMTP on registered annual licensed system
Discussion in '3CX Phone System - General' started by bigohio, Mar 8, 2018.
Tags:
  1. bigohio
    Dec 15, 2009
    What am I missing here?
    I went to check on the SMTP configuration the server drop-down menu is grayed out and I can't change any settings. This is not the freeware edition.
    [​IMG]
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Regarding the error you are getting, this is probably caused because the IP you are sending the request in does not match the IP the last activation happened.
    Please navigate to Settings / Network and set the option to "Dynamic Public IP" under the "External IP Configuration" . Then restart the 3CX services. Wait a few minutes and try again.
