Fortigate SIP ALG Disable steps 5.2 firmware and above
Discussion in '3CX Phone System - General' started by AverageAs, Feb 19, 2017.
  1. AverageAs
    Dec 6, 2016
    11
    9
    Hi All.
    We work a lot with Fortigate firewalls, thought I would share how to disable SIP ALG on firmware 5.2 and above. (Recently done this for a few sites, the steps are slightly different than what is on the 3cx website)
    The below will apply to firmware revision 5.2 and 5.4
    Step 1) Removing the session helper.
    Run the following commands:
    config system session-helper
    show
    Amongst the displayed settings will be one similar to the following example:
    edit 13
    set name sip
    set protocol 17
    set port 5060
    In this example the next commands would be:
    delete 13
    end
    Step 2) Change the default –voip –alg-mode.
    config system settings
    set default-voip-alg-mode kernel-helper-based
    end
    (Version 5.2 and above for this part)
    config voip profile
    edit default
    config sip
    set status disable
    end
    end
    Step 3) Either clear sessions or reboot to make sure changes take effect
    a) To clear sessions
    Ideally you would only delete sessions related to VoIP traffic. However, in the case of SIP, this means not only deleting the SIP control sessions but also all sessions opened to handle the audio (RTP) traffic. If you know the port-range used for the audio traffic, you can be selective with your session clear by first applying a filter.
    See the related article "Troubleshooting Tip : FortiGate Firewall session list information".
    Here is an example based on IP address as a filter.
    FG100E_000000000 # diagnose sys session
    sync List session sync.
    list List session.
    clear Clear the sessions defined by filter.
    stat Stat session.
    full-stat Fully stat session.
    exp-stat Expectation session statistics.
    ttl TTL session.
    filter List session with filters.
    help Session help.
    FG100E_000000000 # diagnose sys session filter
    vd Index of virtual domain. -1 matches all.
    sintf Source interface.
    dintf Destination interface.
    src Source IP address.
    nsrc NAT'd source ip address
    dst Destination IP address.
    proto Protocol number.
    sport Source port.
    nport NAT'd source port
    dport Destination port.
    policy Policy ID.
    expire expire
    duration duration
    proto-state Protocol state.
    session-state1 Session state1.
    session-state2 Session state2.
    clear Clear session filter.
    negate Inverse filter.
    FG100E_000000000 # diagnose sys session filter src
    <xxx.xxx.xxx.xxx> Source IP (from).
    FG100E_000000000 # diagnose sys session filter src 192.168.11.15
    FG100E_000000000 # diagnose sys session list
    session info: proto=6 proto_state=01 duration=2 expire=3599 timeout=3600 flags=00000000 sockflag=00000000 sockport=0 av_idx=0 use=3
    origin-shaper=
    reply-shaper=
    per_ip_shaper=
    ha_id=0 policy_dir=0 tunnel=/ vlan_cos=8/8
    state=local may_dirty
    statistic(bytes/packets/allow_err): org=3964/9/1 reply=3739/8/1 tuples=2
    tx speed(Bps/kbps): 1972/15 rx speed(Bps/kbps): 1860/14
    orgin->sink: org pre->in, reply out->post dev=3->28/28->3 gwy=192.168.11.5/0.0.0.0
    hook=pre dir=org act=noop 192.168.11.15:59274->192.168.11.5:443(0.0.0.0:0)
    hook=post dir=reply act=noop 192.168.11.5:443->192.168.11.15:59274(0.0.0.0:0)
    pos/(before,after) 0/(0,0), 0/(0,0)
    misc=0 policy_id=4294967295 auth_info=0 chk_client_info=0 vd=0
    serial=000002ce tos=ff/ff app_list=0 app=0 url_cat=0
    dd_type=0 dd_mode=0
    npu_state=00000000
    no_ofld_reason: local
    total session 1
    FG100E_000000000 # diagnose sys session clear
    total session 0
    FG100E_000000000 # diagnose sys session filter clear (Clears the filter for the sessions)
    FG100E_000000000 #
    The above example will clear the sessions based on the filter.
    If you had a filter in place make sure to clear the filter first.
    If you wish to clear all active sessions on a fortigate without a filter, T
    he below command will reset all sessions, I have tested and confirmed it will.
    FG100E_000000000 # diagnose system session clear
    b) Alternatively, reboot the FortiGate using either GUI or CLI. The CLI command is:
    execute reboot
    Sources for this are
    http://kb.fortinet.com/kb/documentLink.do?externalID=FD36405
    http://kb.fortinet.com/kb/documentLink.do?externalID=FD33271
    https://www.3cx.com/blog/docs/disable-sip-alg-on-fortigate/
    #1 AverageAs, Feb 19, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Thank you for sharing
  3. blinton
    Dec 12, 2014
    You have a few errors. In step 2) you have
    set default-voip-alg-mode kernel-helper based
    This should be set default-voip-alg-mode kernel-helper-based
    You also have set status enable/disable and I think what you want is set status disable
    In Step 3) the command diagnose system session clear doesn't work
    CentrexJ likes this.
  4. StefanW
    Jun 2, 2009
    1,222
    93
    Hey guys,
    Would you like to work with me in a comprehensive guide for fortigate as we have them for other vendors?
    Fortigate is the number one firewall which due to sip alg causes many users issues with there setup. Not saying that it is the firewalls fault or the implementation is wrong but it is very hard to stop the alg in the device.
  5. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    I can confirm following the instructions above on works and 3cx firewall checker passes nicely. An official document would be greatly appreciated.
    The main thing missing from the 3CX documentation is the line: set default-voip-alg-mode kernel-helper-based without that line i get a full cone nat failure on 5060.
    Fortinet 30E with 5.4.4 firmware 3CX v15.5 Windows.
  6. StefanW
    Jun 2, 2009
    1,222
    93
    We had reached out to Fortigate in the past to do an official IOT and guide but all attempts ended in no communication... So we must build it from the community.
    I have added into the main guide we have, hope it helps others!
  7. AverageAs
    Dec 6, 2016
    11
    9
    Ta, have updated the early errors will confirm the clear command on the firewall I am working on at the moment.
