Forum search
Discussion in '3CX Phone System - General' started by adminjay, Jan 23, 2008.
  1. adminjay
    Dec 3, 2007
    How do you do a search in this Forum?, thanks jay
  2. npyt
    Hello, I was just trying to find a solution for a problem with the SIPURA 3102, and thus needed to search this site also... and thus I found a great way to search the 3Cx site/forum .. and found what seems to be the solution to my sipura problem..
    To search this forum site:
    1) Open up google: http://www.google.com
    2) in the search box type the following text> site:www.3cx.com your_search_text
    Example: site:www.3cx.com 3102 error
    Results: 3Cx Forum posts discussing the sipura 3102 dial out problems...
    saludos,
    Nico
