Forward All Calls got problem.
Discussion in '3CX Phone System - General' started by yadac123, Jan 31, 2008.
  1. yadac123
    Jan 19, 2008
    24
    my extension 100 is not registered to client and it's in red light under line status. I set forward all calls to enable and forward to a outside number but it doesn't do that. why?
    02:14:08.171 Call::RouteFailed [CM503014]: Call(13): Attempt to reach [sip:Q900@127.0.0.1] failed. Reason: Not Registered
    02:14:08.171 CallCtrl::eek:nSelectRouteReq [CM503015]: Call(13): Target is not registered: HuntGrp900:Ext.100
    02:14:06.500 CallCtrl::eek:nLegConnected [CM503007]: Call(13): Device joined: sip:
    02:14:06.390 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(13): Calling: IVR:QueueHandler@[Dev]
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    I have the same problem. You can see that when you let the extension transfer it to another extension he says: xxx@127.0.0.1
    And exactly that is the problem. Donnot ask me how to solve it. I don't know. There should not be the 127.0.0.1 number but the Server IP adress.
  3. yadac123
    Jan 19, 2008
    24
    127 goes back to the host machine but that's not the issue. I don't think they even tested that out.
  4. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    did you have more traces??? i tried also but i can't reproduce it. give plase the traject. ex: 100 calls 101(not registred but forwared to.... 103, 103 registred). thats a easyer way to find it.
  5. yadac123
    Jan 19, 2008
    24
    I'm not forwarding to an extension but to an outside number.
