Forward an extentension to anoter extension
Discussion in '3CX Phone System - General' started by semn, Sep 27, 2010.
  1. semn
    Jan 25, 2010
    21
    Can someone tell me how can i forward an ext ( analog phone connected over an FXS port ) to another extension using only the keypad of the phone. I need something like "fallow me" feature. I read the manual but i don't find any method to do that ( i don't want to use the ext portal to do that because in this room i don't have any computer installed) .
    Thanks George
  2. TotallyVoIP
    Jul 2, 2010
    77
    Not that I know of, but why not set a ring out limit on that phone to then forward to your usual desk/soft ext?
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    If you have set up the different forwarding rules for the extension previously (e.g available, away, out of office, custom1, custom2) then you can change the extension status via the voicemail menu in V9.
    So if you want to forward to another number when you are away set that in the rules then at any time just dial your voicemail and change it in the options to away.
