- Joined
- Sep 24, 2011
- Messages
- 1
- Reaction score
- 0
I'm having an issue with bouncing calls to an external mobile number, either as part of a ring group (forward to outside number) or by creating a forwarding rule for a specific extension to forward the call to 'my mobile number' or 'an external number or skype id'.
I've formatted the number as per the outbound rule created (9 for outside call). Here's a copy of the log. From what I can see there's not much atttempt at an call to the outside world.
I've tried calling 199 (the extension set to forward the call to the mobile number) both internally and from an external phone on a DDI. Extension 100 (the phone I'm calling from) can make outside calls.
18:54:19.721 [CM503020]: Normal call termination. Reason: Not available
18:54:19.721 [CM503016]: Call(3): Attempt to reach <sip:[email protected]> failed. Reason: Not Registered
18:54:19.720 [CM503016]: Call(3): Attempt to reach <sip:[email protected]> failed. Reason: Not Registered
18:54:19.720 [CM503017]: Call(3): Target is not registered: Ext.IVRForward
18:54:19.718 [CM503010]: Making route(s) to <sip:[email protected]>
18:54:19.718 [MS210000] C:3.1:Offer received. RTP connection: 192.168.1.66:4000(4001)
18:54:19.716 Remote SDP is set for legC:3.1
18:54:19.715 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.0.23] PBX contact: [sip:[email protected]:5060]
18:54:19.712 [CM503001]: Call(3): Incoming call from Ext.100 to <sip:[email protected]>
18:54:19.705 [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.66:5060;rport=5060;branch=z9hG4bKPj5T6qTeGwQAFuJAQZ0JdmcTf4ida3YOLG
Max-Forwards: 70
Contact: "Andy"<sip:[email protected]:5060>
To: <sip:[email protected]>
From: "Andy"<sip:[email protected]>;tag=JtnxwHRlSg0bnAKA3b5MKVNY3HB2FVcy
Call-ID: f2rpyW7TkGrcgB2tS2BvDfNCDcBPyJdz
CSeq: 12719 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c04b0f14b26:7cf7ec6c2ed8a0ba94211fac5f3da521",uri="sip:[email protected]:5060",response="f0512b0ccb2099a6739107d56f013bc6",algorithm=MD5
Supported: replaces, 100rel, timer, norefersub
User-Agent: 3CXPhone for iPhone 1.0.23
Content-Length: 0
Any help greatly appreciated!
Max-Forwards: 70
CSeq: 12719 INVITE
Min-SE: 90
Content-Length: 0
