forward call, i want callerID the ID of the caller
Discussion in '3CX Phone System - General' started by robgielen, May 9, 2008.
  1. robgielen
    Mar 17, 2008
    I have one problem. If i forward a call to the cellphone. The number on the display is the number of my office. Is it possible to send me also the number of the caller who called me?
    for example:
    office: 0001111222
    caller: 0123456789
    0123456789 call's our office
    in 3cx i forward the call to my cellphone.
    on my cellphone there is the number of the office: 0001111222. Can i change that?
    Rob
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    The caller ID to your mobile is provided by your mobile operator. Since your mobile operator receives a request to call your mobile from a PSTN line - it provides the PSTN line number as a caller ID.
  3. Halea
    Halea New Member
    Jan 5, 2008
    151
    Archie,
    Isn't it that caller ID consists of two fields; one which is the phone number (and you cannot touch it - the actual carrier sets its content) and the other a user definable name or alphanumeric string?
    Couldn't you have the 3CX software to read the incoming caller ID phone number and put it in the user definable caller name field as the call is forwarded to another number?
    Don't you think that such a capability would be useful?
    Halea
  4. coslau
    Sep 28, 2009
    6
    I do !
    We have the same need, when forwarding direcly to our PABX... we would like to see original callerid
  5. leejor
    10,360
    226
    This would work only if, (A) You are using a VoIP provider for the outgoing portion of the call (to the mobile) AND (B) Your VoIP provider allows you to change the number that they pass on to the person you are calling.
    So, if your call is going out through a gateway to a PSTN line then you are out of luck as the PSTN provider will only pass on the outgoing line number or your main billing (incoming) number, depending on how you have arranged it with them
  6. mobidutch
    Feb 6, 2010
    26
    So..suppose that my VOIP provider allows that caller ID substitution, how can I configure 3CX to make that happen?
  7. leejor
    10,360
    226
    This subject has come up many times, here's one of them.
    http://www.3cx.com/forums/passing-callerid-on-forwarding-with-v8-12035.html#p70229
  8. mobidutch
    Feb 6, 2010
    26
    Thx for the link...unfortunately that thread is open ended, does not say if it is or is not possible. I'll have to play around with it a bit, I suppose.
  9. jim@itstod.se
    jim@itstod.se New Member
    Apr 7, 2008
    100
    Here you can place a vote for this feature.
    http://www.3cx.com/forums/keep-pstn-caller-id-on-forward-from-voip-to-voip-10535.html
