forward caller id ?
Discussion in '3CX Phone System - General' started by amygoda, Aug 20, 2008.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello all
    if a call forward to external voip line
    can caller id forward with it?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    This is not possible to do. the PABX will be acting as a relay for the call and thus the number you call will show the CSID of the line used by the PABX to call out.
    regards
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Alex,
    thank you for reply
    is it can be after the call answered or a new feature ?
  4. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    You can try to post as a feature request, however using somelses CID needs to be allowed by the telco and i have never seen that.
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Thank you William and Matt for reply
    I wonder if it's possible when external line is voip provider
  6. c.holloway
    Oct 24, 2014
    50
    I realize this is an old post but wanted to follow up for anyone else searching this topic.
    On a SIP trunk, if you want to preserve the external caller ID on a call that fowards out go to the Outbound Parameters tab of your SIP trunk and change the fields "Remote Party ID - Calling Party: Display Name" and "Remote Party ID - Calling Party: User Part" from the default to "OriginatorCallerID"
  7. leejor
    11,291
    361
    I went through this a bit more recently....
    http://www.3cx.com/forums/caller-id-not-being-passed-onto-mobile-40795.html
