forward calls from extension in ring group
Discussion in '3CX Phone System - General' started by t4mack, Mar 4, 2010.
  1. t4mack
    Jan 19, 2010
    56
    I want to forward a call from an extension in a ring group. I have set the status to away and created a forwarding rule but it doesn't work. I even tried putting the phone on do not disturb but that didn't work. Here is the scenario. Call comes in to ring group 0 and ring extension 10,11, and 12. I want to be able to have extension 12 set their status to away and the call be forwarded to extension 20. It works if the call doesn't go to the ring group so i was wondering if there was something in the custom parameters that needs to be changed.
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    That can't work, because extension 12 doesn't own the call - so it's forwarding rules don't apply. The ring group owns the call until the ring time is exceeded, at which time the action you specify in the ring group is taken. So you really want to specify this action at the ring group, not the extension.
