Forward calls to external number
Discussion in '3CX Phone System - General' started by JackH, Mar 7, 2018.
  1. JackH
    Aug 4, 2017
    Let's say I want to forward all calls made to a specific DDI to an external number; is it possible to have the CLI present as the dialled number? Rather than the call originator's number.
    0111111111 calls 022222222 which then forwards to 0333333333
    0333333333 see's that a call is incoming from 022222222
    With the way I currently have it set up (forwarding extension to mobile using Call Deflection - only way I could get it to work at all);
    0333333333 see's that a call is incoming from 0111111111
    I hope that makes sense!
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    In many cases, yes, but it may depend on what the provider wants to see and how the headers in the messaging are formulated.
    The redirection (deflection) is, I assume, using a call diversion message. Essentially, this is when a call comes in and the PBX tells the originator that the intended destination is not available here, but to go "there" now. Think of this as a detour.
    Many providers do not like diversion headers and instead will only want to see a new INVITE. The implication being that instead of a detour, the call is answered (INVITE is answered, but not physically per se) and then a forward using a new INVITE is initiated.
    You likely need to do a capture without the divert function enabled to see what is standing in the way of the new call being successful.
    JCLloyd likes this.
  3. leejor
    I'm not certain that showing the DID number, as outbound caller ID is a straight forward thing to implement, if at all.
