Solved Forward extension on unregistered only
Discussion in '3CX Phone System - General' started by Tom Cowley, Sep 12, 2017.
  1. Tom Cowley
    Aug 21, 2017
    8
    I want to be able to set a particular phone to forward on unregistered only. I can see an option for ‘forward on unregistered or busy’, but I do not want to forward it if the phone is busy. Do you know if it’s possible to do this?
    The scenario is if the site has a power cut. I want to be able to forward the main reception phone to a backup analogue line.
    Thanks.
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Tom Cowley,
    Try enabling the "Accept Multiple Calls" parameter in the extension's Forwarding Rules. This will enable the extension to basically not be busy. So when that extension is already on a call, and receives another, the forwarding will not take place.
  3. Tom Cowley
    Aug 21, 2017
    8
    Hi there,
    I just configured it on a test phone and it works great. Thanks for you rapid response @Panayiotis_3CX
    Tom
    Panayiotis_3CX likes this.
  4. Panayiotis_3CX
    Apr 26, 2017
    165
    7
    @Tom Cowley,
    Glad I could help :)
    #4 Panayiotis_3CX, Sep 12, 2017
