Setup the trunk and outbound rules, but still not getting processed correctly. Included snippet from the logs showing a successful call through 3cx using direct sip dialing and the failed call which is placed to an internal extension with the phone unregistered and set to forward.
Thanks for your help.
Failed call from 650 to unregistered 651 setup to forward to <sip:
[email protected]>
14:22:21.003 [CM503020]: Normal call termination. Reason: Terminated
14:22:21.003 [CM503016]: Call(123): Attempt to reach <sip:
[email protected]> failed. Reason: Not Acceptable HereReason Unknown
14:22:21.003 [CM503003]: Call(123): Call to sip:%3Csip%3Amy_username%40iptel.org%
[email protected]:5060 has failed; Cause: 407 Proxy Authentication Required; warning: Noisy feedback tells: pid=29557 req_src_ip=xxx.xxx.xxx.xxx req_src_port=62077 in_uri=sip:%3Csip%3Amy_username%40iptel.org%
[email protected]:5060 out_uri=sip:%3Csip%3Amy_username%40iptel.org%
[email protected]:5060 via_cnt==1; from IP:xxx.xxx.xxx.xxx:5060
14:22:17.894 [CM503025]: Call(123): Calling VoIPline:<sip:
[email protected]>@(Ln.10000@iptel-trunk)@[Dev:sip:
[email protected]:5060]
14:22:16.972 [CM503005]: Call(123): Forwarding: VoIPline:<sip:
14:22:16.972 [CM503016]: Call(123): Attempt to reach <sip:
[email protected]> failed. Reason: Not Registered
14:22:16.972 [CM503017]: Call(123): Target is not registered: Ext.651
14:22:16.972 [CM503010]: Making route(s) to <sip:
[email protected]>
14:22:16.972 [CM505001]: Ext.650: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite 4 release 4.1 stamp 63214] PBX contact: [sip:
[email protected]:5060;transport=TCP]
14:22:16.972 [CM503001]: Call(123): Incoming call from Ext.650 to <sip:
[email protected]>
Successful call from 650 to
[email protected].
14:28:10.695 [CM503007]: Call(125): Device joined: sip:
[email protected]
[email protected]:54622;transport=TCP
14:28:07.211 [CM505001]: Ext.my_username: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
[email protected]:62140]
14:28:07.211 [CM503002]: Call(125): Alerting sip:
[email protected]
14:28:02.211 [CM503025]: Call(125): Calling Ext:Sip.DirectSIP@[Dev:sip:
[email protected]]
14:28:01.273 [CM503004]: Call(125): Route 1: Ext:Sip.DirectSIP@[Dev:sip:
[email protected]]
14:28:01.273 [CM503010]: Making route(s) to <sip:
[email protected]>
14:28:01.273 [CM505001]: Ext.650: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite 4 release 4.1 stamp 63214] PBX contact: [sip:
14:28:01.273 [CM503001]: Call(125): Incoming call from Ext.650 to <sip:
[email protected]>
