Forward extension to external not showing in Reports
Discussion in '3CX Phone System - General' started by za-aritechbiz, Nov 19, 2014.
  1. za-aritechbiz
    Sep 13, 2010
    6
    Hi there
    I have on V12 one extension using forward rule to forward calls to external number. But when using the reporter it does not show those calls forwarded to external on the extension detail.
    Is there a way to see those calls in the extension report?
    Regards
    Johan
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    you may see the forwarded call to the external number on the Call Statistics Reports>> Call Logs.
    Please check it .
  3. za-aritechbiz
    Sep 13, 2010
    6
    Hi, I have looked and searched for the number I am forwarding to but cannot find any result containing it.
