forward rules
Discussion in '3CX Phone System - General' started by tranza, Jul 30, 2010.
  1. tranza
    Jul 29, 2010
    8
    I have set a rule to one of our users (Matt) after 10 seconds of ringing it forwards the call to a ring group. When the call gets forwarded it stops ringing in Matt's phone even tough he is in the group, he wishes it to continue to ring to his phone.
    Cheers, Tom
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,559
    118
    What version of the PBX are you using?
    Also what phones are we talking about?
    Can you post a snippet of the logs in verbose mode?
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    This was a know issue in previous version of the PBX, but in the latest builds had been fixed. Please advise your current build number and if it is not the latest please upgrade to the most recent version of 8 or the new version of 9.
  4. tranza
    Jul 29, 2010
    8
    we are using version 9 with the latest service pack (1), the phones are polycom 4020
    Code:
    log:
    16:41:32.590  [CM505001]: Ext.113: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:113@192.168.120.6:5060]
    16:41:32.590  [CM503002]: Call(61): Alerting sip:113@192.168.120.23:5060
    16:41:32.391  [CM505001]: Ext.112: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:112@192.168.120.6:5060]
    16:41:32.391  [CM503002]: Call(61): Alerting sip:112@192.168.120.23:5060
    16:41:32.032  [CM505001]: Ext.108: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:108@192.168.120.6:5060]
    16:41:32.032  [CM503002]: Call(61): Alerting sip:108@192.168.120.23:5060
    16:41:31.883  [CM505001]: Ext.106: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:106@192.168.120.6:5060]
    16:41:31.883  [CM503002]: Call(61): Alerting sip:106@192.168.120.23:5060
    16:41:31.511  [CM505001]: Ext.107: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:107@192.168.120.6:5060]
    16:41:31.511  [CM503002]: Call(61): Alerting sip:107@192.168.120.23:5060
    16:41:31.392  [CM505001]: Ext.104: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:104@192.168.120.6:5060]
    16:41:31.392  [CM503002]: Call(61): Alerting sip:104@192.168.120.23:5060
    16:41:30.712  [CM505001]: Ext.111: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:111@192.168.120.6:5060]
    16:41:30.712  [CM503002]: Call(61): Alerting sip:111@192.168.120.23:5060
    16:41:29.800  [CM503003]: Call(61): Call to sip:105@192.168.120.6 has failed; Cause: 486 Busy Here; from IP:192.168.120.23:5060
    16:41:29.699  [CM503003]: Call(61): Call to sip:105@192.168.120.6 has failed; Cause: 487 Request Cancelled; from IP:192.168.120.23:5060
    16:41:29.698  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:114@192.168.120.23:5060]
    16:41:29.697  [MS210006] C:61.11:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.693  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:113@192.168.120.23:5060]
    16:41:29.692  [MS210006] C:61.10:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.689  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:112@192.168.120.23:5060]
    16:41:29.688  [MS210006] C:61.9:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.684  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:111@192.168.120.23:5060]
    16:41:29.683  [MS210006] C:61.8:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.680  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:108@192.168.120.23:5060]
    16:41:29.679  [MS210006] C:61.7:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.675  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:107@192.168.120.23:5060]
    16:41:29.674  [MS210006] C:61.6:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.670  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:106@192.168.120.23:5060]
    16:41:29.669  [MS210006] C:61.5:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.665  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:105@192.168.120.23:5060]
    16:41:29.664  [MS210006] C:61.4:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.661  [CM503025]: Call(61): Calling RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:104@192.168.120.23:5060]
    16:41:29.659  [MS210006] C:61.3:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:29.618  [CM503005]: Call(61): Forwarding: RingAll333:104Ext.104103105Ext.105106Ext.106107Ext.107108Ext.108111Ext.111112Ext.112113Ext.113114Ext.114@[Dev:sip:104@192.168.120.23:5060,Dev:sip:105@192.168.120.23:5060,Dev:sip:106@192.168.120.23:5060,Dev:sip:107@192.168.120.23:5060,Dev:sip:108@192.168.120.23:5060,Dev:sip:111@192.168.120.23:5060,Dev:sip:112@192.168.120.23:5060,Dev:sip:113@192.168.120.23:5060,Dev:sip:114@192.168.120.23:5060]
    16:41:23.960  Currently active calls - 2: [53,61]
    16:41:21.093  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [KIRK Wireless Server 6000 PCS05D_ r26242] PBX contact: [sip:105@192.168.120.6:5060]
    16:41:21.093  [CM503002]: Call(61): Alerting sip:105@192.168.120.23:5060
    16:41:19.552  [CM503025]: Call(61): Calling Ext:Ext.105@[Dev:sip:105@192.168.120.23:5060]
    16:41:19.550  [MS210006] C:61.2:Offer provided. Connection(by pass mode): 192.168.120.7:9014(9015)
    16:41:19.507  [CM503004]: Call(61): Route 1: Ext:Ext.105@[Dev:sip:105@192.168.120.23:5060]
    16:41:19.505  [CM503010]: Making route(s) to <sip:105@192.168.120.6:5060>
    16:41:19.505  [MS210000] C:61.1:Offer received. RTP connection: 192.168.120.7:9014(9015)
    16:41:19.503  Remote SDP is set for legC:61.1
    16:41:19.503  [CM505001]: Ext.119: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13527.0] PBX contact: [sip:119@192.168.120.6:5060]
    16:41:19.499  [CM503001]: Call(61): Incoming call from Ext.119 to <sip:105@192.168.120.6:5060>
    16:41:19.495  [CM500002]: Info on incoming INVITE:
      INVITE sip:105@192.168.120.6:5060 SIP/2.0
      Via: SIP/2.0/UDP 192.168.120.6:65066;branch=z9hG4bK-d8754z-d73d6021b46d5013-1---d8754z-;rport=65066
      Max-Forwards: 70
      Contact: <sip:119@192.168.120.6:65066;rinstance=039fb1732f0748b5>
      To: <sip:105@192.168.120.6:5060>
      From: "130"<sip:119@192.168.120.6:5060>;tag=17405d66
      Call-ID: OTc4OGJmYTdjNWQxNjc5MjRmZmM2OGZhYzhhNmU3ODQ.
      CSeq: 2 INVITE
      Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
      Proxy-Authorization: Digest username="119",realm="3CXPhoneSystem",nonce="414d535c026cb00f76:58fcadc70073a8d7d813c835b9da2450",uri="sip:105@192.168.120.6:5060",response="13b58228adf510cabf508ab73bc65185",algorithm=MD5
      Supported: replaces
      User-Agent: 3CXPhone 4.0.13527.0
      Content-Length: 0
  5. tranza
    Jul 29, 2010
    8
    any ideas?
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    What extension is the forward all to mobile set on?
    Also do you have paid support?
  7. tranza
    Jul 29, 2010
    8
    yes we have payed support i just hate calling :p the extension is set to if no answer in 10sec's it calls the ring group in that ring group the extension is in also.
