Forward to Cell Fails
Discussion in '3CX Phone System - General' started by mantalope, Sep 25, 2014.
  1. mantalope
    Mar 10, 2011
    35
    I have a Cisco 504g and an extension that has been configured for the past several years to ring for 10 seconds and then forward to a cell phone. This has worked without issue until last week. Now, the handset rings as expected, and the call is forwarded to the cell, as expected, and the cell phone rings. When the user answers the cell phone, the call is dropped immediately. This is only happening for this one extension.
    Here'e the server activity for one of the failed calls:
    25-Sep-2014 17:22:21.319 Leg L:938.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 69.255.179.87:5060
    25-Sep-2014 17:22:21.175 L:938.1[Line:10002<<585755XXXX] forwards call from Extn:867 to Out#:>>Rule{11 Digits}>>1703622XXXX based on rule Fwd[Available/NoAnsw]
    25-Sep-2014 17:22:21.175 L:938.1[Line:10002<<585755XXXX] failed to reach Extn:867, reason No Answer
    25-Sep-2014 17:22:11.154 [CM503025]: Call(C:938): Calling T:Extn:867@[Dev:sip:867@69.255.179.87:5060] for L:938.1[Line:10002<<585755XXXX]
    25-Sep-2014 17:22:11.100 [CM503027]: Call(C:938): From: Line:10002<<585755XXXX ("WIRELESS CALLER" <sip:585755XXXX@voip.raland.com:5060>) to T:Extn:867@[Dev:sip:867@69.255.179.87:5060]
    Does anyone have any insight as to why this may be happening?
    10,367
    228
    Do the extensions, where this continues to work, use the same wireless provide, outgoing trunks? Have you compared a 3CX log for a working call and this one that fails?
  3. mantalope
    Mar 10, 2011
    35
    In our tests, a Verizon cell phone called into the system and was forwarded to another Verizon cell phone. Originating call from from NY and the destination was in VA.
    I looked at the good/bad logs, and did not notice any difference, but will review again. It appears that the problem occurs when 3CX hands off the call to the two parties (calling and receiving).
    The strange thing is that the problem appeared suddenly to an extension that has been working fine for several years. Nothing has changed on our system or on the user's system (to the best ok my knowledge). I contacted our VoIP provider (Windstream) and they pushed the blame back onto our 3CX PBX.
    We also have another issue where outside calls coming into 3CX and routed to an external handset are disconnected when the user picks up the handset. Voicemail to that extension works fine and internal calls work fine. This extension has just been reconnected after sitting idle for several months. I don't know that these issues are related to the same problem or not.
  4. leejor
    10,367
    228
    Many time, when this happens, it's after about 30 seconds, and the 3CX log for the call will show No ACK Received. Even though the call seems to connect, it is dropped after a 30 second (or so) timeout (waiting) period.
    In some cases, even though you don't think anything has changed at your end, it may have. That said, it may also be that your provider that has changed how they handle calls, and unless the person that you spoke with works on the equipment, they may not even be aware of it.
    The call will still pass through 3CX, so unlike two 3CX extensions "talking" (with NO PBX Delivers Audio option selected), the call is not handed off to the two parties.
    You may have to incorporate on something like Wireshark to see the differences between a working and non-working call. that might give you some "ammo" when you go back to your provider.
  5. mantalope
    Mar 10, 2011
    35
    Thanks for your help on this. I plan to set up a test phone to see if I can duplicate these problems in a more controlled environment.
  6. mantalope
    Mar 10, 2011
    35
    After setting up a test phone, duplicating the problem, and troubleshooting, I found that disabling NAT and changing the SIP Transport from UDP to TCP on our Cisco SPA 504g handsets solved the problem.
    Thanks again for your help.
