Forward to Different External Numbers at Different Times
Discussion in '3CX Phone System - General' started by matt11, Jul 30, 2013.
  1. matt11
    Jul 30, 2013
    One of our clients is manually having to change what a ring group calls before every weekend for those who are on call (they split out the time during the days to different numbers). I can't seem to find a good solution to this. I tried creating an extension that will be sent to after hours and then doing an exception forward, but the exceptions require a certain callerid. Is there a wildcard that would work for any call? Is there a better solution to this?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    I am not sure I understand the scenario as I keep wondering why not simply create a second ring group that comes into play during non-office hours that dials what you need?
  3. matt11
    Jul 30, 2013
    If different ring groups can be called at different set times on different days, then that would work just as well. I just am unaware as to how I would be able to set that. I know you can set a ring group to ring outside of business hours, which is their current setup. They just need a different cell phone to ring after 5pm weekdays, and then a different one at certain times on the weekend.
  4. lneblett
    Sep 7, 2010
    2,086
    64
    I get more of it now.
    you might look at http://www.voiptoys.com as they may have a solution that fits.
  5. matt11
    Jul 30, 2013
    I was beginning to think there wasn't going to be an easy way to do it. I suppose that company's call router would probably be the best method. They are pretty cost conscious, so I don't know if they would be up to buying it, even if it probably saves them a lot more time than what they are doing now.
  6. lneblett
    Sep 7, 2010
    2,086
    64
    Well, the real issue is that they need to be specific in what they want and then it needs to be repeatable. Once the specifics are known, then there may be a way using a combination of both global and extension specific business hours to formulate a solution even if somewhat convoluted. Otherwise VoIPToys looks like the only viable option for a programmable solution.
