Forward to external call with original caller id
Discussion in '3CX Phone System - General' started by Hatschipu, Sep 18, 2015.
  1. Hatschipu
    Sep 18, 2015
    Hi there,
    read many topics but didn't get answers so far. We have a 3cx 12.5 with SP1 system and have problems to foward
    incoming calls to a external number ( eg. mobile phone ) in the first step. No matter which settings i do, the incoming call
    isn't fowarded immediately. It takes up to 10 seconds. Next problem is the original caller id isn't forwared eather.
    My Voip Provider supports this feature, but i can't get it to work with my 3cx systems. Any ideas ? Or does someone have the same problem and solved it ?
    Regards
    Christian
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    It depends on which fields in the SIP headers that your provider uses to detect and forward the original calling CID. This is what my provider (nexVortex) uses:
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    Many I have tried use the "From: User Part" set to "Originator Caller ID". However, not all providers support changing this field.
