Forward To External Number: An unhandled exception
Discussion in '3CX Phone System - General' started by Spyklee, Feb 23, 2009.
  1. Spyklee
    Nov 1, 2007
    45
    I'm running the latest version 7.0.4744 of 3CX and experiencing some difficulties configuring a forward rule to dail an external number if the call isn't answered.
    Using these settings;
    Rule Type: No Answer
    Hours: All Hours
    Call Type: All Calls
    Action: Forward Call to External Number
    Destination: is a Dutch 10 digit cell phone numbr
    After the 'Add Rule' Button the following error occurs:
    After the Clear Button the rule has been added, but it's not working correctly.
    Also the Continue Ringing value in General Forwarding Options, although I change the value to 10 sec. that's about 3 rings it will return to 60 again after refreshing the window, or selecting the forward rule.
    Any idea?
  2. Spyklee
    Nov 1, 2007
    45
    I Did some additional tests, the error doesn't occur if you use the /MyPhone webinterface. However it doesn't resolve the issue.
    It seems that it's not using the forward rules, I changes the No Answer Rule to Forward All but the Extension is still ringing.
    Below the log file of the incoming cal. It ends after the No Answer, it should be handled by the rule.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    This is a known issue and has been fixed in the Upcoming Release.
  4. Spyklee
    Nov 1, 2007
    45
    Thanks for the (fast) reply!
    Do you have an E.T.A. for this upcoming release?
  5. LeonidasG
    Nov 19, 2008
    1,473
    94
    Unfortunately i cannot say.
    I dont have an exact E.T.A, but i can say it's gonna be very soon ;P
