Forward to external number that is bussy
Discussion in '3CX Phone System - General' started by ansu2723, Apr 21, 2009.
  1. ansu2723
    Nov 23, 2008
    29
    I wonder how it works. If you forward to an external number and that number is bussy. Can the call return to the PBX voicemail then?
    It should be possible to detect that the phone is bussy.
    Best regards
    Andreas
    Sweden
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    There are many factors in play here so a Yes / no answer would not be correct.
    1. Gateway setup and type of gateway
    2. Provider and provider based settings.
    It would be ideal that you advise the issue you are having in this respect with your settings for the specific gateway / provider and extension if you are diverting outside via extension forwarding rules.
