Forward to external number
Discussion in '3CX Phone System - General' started by arkitekt, Sep 30, 2009.
  1. arkitekt
    Jul 6, 2009
    14
    I've been wondering if there's a way to include an external number in a ring group so that calls to a particular group can also ring an external cell phone number.
    Could anyone point me in the right direction or suggest an alternative solution?
    Nathan
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Yes, this works quite well in v8. I don't know if it worked in previous version.
  3. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    There is an additional setting that must be enabled to allow it to work. Check the admin console.
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,581
    119
    You can add an Unregistered extension to the Ring Group that has a Forwarding rule: Forward all > All Times > All Calls > External Number:XXXXXXXX
    Then go to Settings > General Settings > Global Options > Allow Call to be forwarded in ring groups to external numbers: Tick it.
    Done.
