forward to external number
Discussion in '3CX Phone System - General' started by cfive, Nov 19, 2009.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    I have an extension, forwarding rules include:
    Phone Busy | out of office hours | all calls | forward to external number xxx-xxxx
    No Answer | out of office hours | all calls | forward to external number xxx-xxxx
    Fine up until [no answer], and then "no outbound lines were availalbe for this call", and the call ends.
    3cx log shows: There's no outbound rule for external number 'xxxxxxx' defined.
    OK, seems pretty straight forward ;-). Except, what would the outbound rule look like ;-/. I have a rule that allows the extension to dial outbound, but I guess I need something else more specific.
    I have Allow forwarding to externalnumbers in ring groups Queues on/off selected, in Global options. Not sure if that's got anything to do with it, though.
    Thanks - Les.
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Well, it was pretty straight forward ;-).
    I have an outbound rule which includes phone extension numbers - I don't know why that wouldn't have worked unless the forward is actually initiated from an extension *other* than a phone extension number.
    A new rule specifying 100-999 allows the forward. But that kind of defeats other rules that restrict certain phone extensions to certain gateways :-(. I need to narrow it down a bit.
    Thanks - Les.
  3. leejor
    10,872
    305
    Perhaps there is a range of 3 digit numbers that are used internally when forwarding a call. You could experiment by "shrinking" the allowed range until it doesn't work any more, finally narrowing down to what the "magic" numbers are.
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    I should be able to determine that from the logs ;-).
    Love your tag line WEsT, my sympathies :).
  5. pjr
    pjr New Member
    Oct 5, 2009
    154
    if not the logs a wireshark capture should show it?
  6. leejor
    10,872
    305
    Wireshark won't show it as it seems to be an internal "restriction" based on the extension number range, so far anyway. If the call was failing after leaving 3Cx then Wireshark can help pinpoint the reason. The 3CX logs may help if they can give more info than "no route found"
  7. leejor
    10,872
    305
    If the past summer is an indication of future weather trends, we may be wishing that it were more true.
