I am also receiving this error.
Have you got it working genesi or not yet?
Here is a extract from my logs:
27-Aug-2014 09:45:36.116 L:144.1[Line:10021<<+2781xxxxxxx] failed to reach Line:10021>>079xxxxxxx, reason Forbidden
27-Aug-2014 09:45:36.113 Leg L:144.3[Line:10021>>079xxxxxxx] is terminated: Cause: 403 Do not use late offer-answer model/INVITE from 41.xx.xx.xx:5060
27-Aug-2014 09:45:36.113 Call to T:Line:10021>>079xxxxxxx@[Dev:sip:
[email protected]:5060] from L:144.1[Line:10021<<+2781xxxxxxx] failed, cause: Cause: 403 Do not use late offer-answer model/INVITE from 41.xx.xx.xx:5060
27-Aug-2014 09:45:36.112 [CM503003]: Call(C:144): Call to <sip:
[email protected]:5060> has failed; Cause: 403 Do not use late offer-answer model/INVITE from 41.xx.xx.xx:5060 :cry:
27-Aug-2014 09:45:35.988 [CM503025]: Call(C:144): Calling T:Line:10021>>079xxxxxxx@[Dev:sip:
[email protected]:5060] for L:144.1[Line:10021<<+2781xxxxxxx]
27-Aug-2014 09:45:35.935 [CM503005]: Call(C:144): Forwarding: T:Line:10021>>079xxxxxxx@[Dev:sip:
27-Aug-2014 09:45:35.934 L:144.1[Line:10021<<+2781xxxxxxx] forwards call from Extn:399 to Out#:>>Rule{Head Office}>>079xxxxxxx based on rule Fwd[Available/NotReg]
27-Aug-2014 09:45:35.934 L:144.1[Line:10021<<+2781xxxxxxx] failed to reach Extn:399, reason Not Registered
27-Aug-2014 09:45:35.934 [CM503017]: Call(C:144): Target is not registered: Extn:399
27-Aug-2014 09:45:22.034 [CM503007]: Call(C:144): Ivr:805 has joined, contact <sip:
[email protected]:40600>
27-Aug-2014 09:45:22.030 [CM503007]: Call(C:144): Line:10021<<+2781xxxxxxx has joined, contact <sip:
To explain what what is in these logs:
2712xxxxxxx - main SIP Trunk on 3CX
41.xx.xx.xx - IP of SIP Trunk provider
Extn:399 - the dummy extension that needs to forward to a external number
2781xxxxxxx - external number dialed from
079xxxxxxx - Mobile number to forward to
When calling ext 399 form a local extension it forwards with no problem, its only when a external number calls in and then needs to forward. The option in Settings/General that allows forwardings to external numbers from queue/ring groups is checked.
3CX Version 12 SP6.1
Any help would be greatly appreciated.
Regards,
Ralph
