Forward "* to operator" to an extension or phone
Discussion in '3CX Phone System - General' started by MFreid, Nov 24, 2014.
  1. MFreid
    Oct 27, 2014
    16
    Hey guys.
    Currently in our system, if someone gets the default voicemail message it says "leave a VM or press star to go to operator."
    We do not have an operator or receptionist for the purpose of taking and forwarding calls. As such, when hitting *, the same message just repeats.
    We would like it so that if someone hits star (*) that it instead forwards to a virtual extension/queue.
    OR worst case scenario, how do we change the default voicemail greeting?
    Thank you
    Mark Freid | Leapset IT
    http://www.leapset.com
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,128
    207
    You could setup a dummy operator extension and forward all calls to wherever.
    then change settings-> general -> operator to this new extension.
    Settings-> system prompts is the prompt file - but I am not sure the default vm greeting is in there.
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    On almost all new configs, I create the Operator extension when creating the PBX through the initial wizard.. then tell it to be the operator extension accordingly.
    Craig is correct, from there you can direct/route the calls as you see fit using a rule there. I typically route them to an IVR if it makes sense to do so.. but have also routed them to a "General Voicemail" extension instead.
    I also tend to use that same Operator to direct most traffic.. but do find that the "star" option may be a special case instead of the general one.. and thus should be treated/routed differently than most incoming calls..
