Forward To Outside Number - Caller Can't Hear Other Person
Discussion in '3CX Phone System - General' started by bac, Feb 15, 2008.
  1. bac
    bac
    Feb 10, 2008
    7
    I have extension 10 set up to forward all calls to an outside number.
    When I make a test call into the system and then dial extension 10, the call is connected to the outside number, but I cannot hear the other person. The person on the outside number can hear me however.
    What would be the most likely cause of this?
    Brian
  2. novastar
    Jul 16, 2007
    15
    Same problem here. Don't have a clue either...
  3. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    Please make sure under "other option" (Manage Extensions) you select: "PBX delivers Audio"
