Forward to Outside Number Problem from Ring Group
Discussion in '3CX Phone System - General' started by muaddib32, Sep 2, 2011.
  1. muaddib32
    Oct 16, 2010
    68
    Trying to forward unanswered calls to an external answering service. This works fine for an extension. But because I want calls to be handled differently during work hours and after-hours I have set up a ring group. But the ring group will not forward calls to an external number. I have checked the box "Allow forwarding to external numbers.." in General, Settings.
    How do I get this to work?
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    hello,
    How do you have calls handled generally outside of office hours? do you allow external calls outside of office hours?
    do you have external calls on your trunks disabled outside office hours?
    Thanks,
    Nate
  3. muaddib32
    Oct 16, 2010
    68
    Does it matter? I am trying to get the system to forward unanswered calls during work hours to an external number using a ring group.
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    It does actually, you didn't specify in or out of office hours, now I know you mean in office hours so now it doesn't matter. Have you checked the logs too see why it is not working?
    did you format the number to work with your outbound rules?
  5. muaddib32
    Oct 16, 2010
    68
    It works fine when diverting from an extension
  6. muaddib32
    Oct 16, 2010
    68
    The Server Activity Log says that the call was terminated. No Answer. It is supposed to be forwarding not terminating
  7. leejor
    10,360
    226
    Post the log of a failed call. I assume that there is a spare trunk available for the call.
  8. muaddib32
    Oct 16, 2010
    68
    -There is only the one line, but it works when forwarded from an extension
    09:51:27.471 [CM503003]: Call(2): Call to sip:100@192.168.64.7 has failed; Cause: 487 Terminated; from IP:192.168.64.14:5060
    09:51:27.369 [CM503020]: Normal call termination. Reason: No answer
    09:51:27.369 [CM503016]: Call(2): Attempt to reach <sip:800@192.168.64.7:5060> failed. Reason: No Answer
    09:51:24.929 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [DPH 125MS 1.14.27] PBX contact: [sip:100@192.168.64.7:5060]
    09:51:24.928 [CM503002]: Call(2): Alerting sip:100@192.168.64.14:5060
    09:51:24.252 [CM503025]: Call(2): Calling RingAll800:100Ext.100@[Dev:sip:100@192.168.64.14:5060]
    09:51:24.248 [MS210002] C:2.2:Offer provided. Connection(transcoding mode): 192.168.64.7:7002(7003)
    09:51:24.219 [CM503004]: Call(2): Route 1: RingAll800:100Ext.100@[Dev:sip:100@192.168.64.14:5060]
    09:51:24.215 [CM503010]: Making route(s) to <sip:800@192.168.64.7:5060>
    09:51:24.213 [MS210000] C:2.1:Offer received. RTP connection: 203.176.185.10:38350(38351)
    09:51:24.208 Remote SDP is set for legC:2.1
    09:51:24.206 [CM505003]: Provider:[Comvergence] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sippy] PBX contact: [sip:61390085250@150.101.163.242:5060]
    09:51:24.197 [CM503001]: Call(2): Incoming call from 0418146132@(Ln.10001@Comvergence) to <sip:800@192.168.64.7:5060>
    09:51:23.896 [CM503012]: Inbound outside specific hours incl. holidays rule (unnamed) for 10001 forwards to DN:800
    09:51:23.895 Looking for inbound target: called=61390085250; caller=0418146132
    09:51:23.885 [CM500002]: Info on incoming INVITE:
    INVITE sip:61390085250@192.168.64.7:5060;rinstance=661038a060db3992 SIP/2.0
    Via: SIP/2.0/UDP 203.176.185.10;branch=z9hG4bK5fe6.1bbe0f98b56544654b4383fb1a562191.0
    Via: SIP/2.0/UDP 203.176.185.10:5061;branch=z9hG4bK047320b5b6efc7f4fe330b96f5c7f6f7;rport=5061
    Max-Forwards: 16
    Record-Route: <sip:203.176.185.10;ftag=e81e1dd3a01ad5346039b5962d158356;lr>
    Contact: "Anonymous"<sip:203.176.185.10:5061>
    To: <sip:61390085250@203.176.185.10>
    From: <sip:0418146132@203.176.185.10>;tag=e81e1dd3a01ad5346039b5962d158356
    Call-ID: call-71A2623A-40B8-2E10-0B06-3E0C2@203.176.186.10~1o
    CSeq: 200 INVITE
    Expires: 300
    User-Agent: Sippy
    Content-Length: 0
    cisco-GUID: 879048241-1714970979-1717986918-1697669730
    h323-conf-id: 879048241-1714970979-1717986918-1697669730
  9. leejor
    10,360
    226
    You mean you only have one trunk? Hmmmm
    If you do have more than one trunk...
    What you can try...is create a dummy extension, say, 200. This doesn't require that you have a physical set., forward that extension to your outside number. Call it (200) directly to be sure it works. Next forward the unanswered call in the ring-group to 200. Call the ring-group (800) from an extension (not the one in the group), does it forward to the outside number if not answered? If yes, then try an outside call.
  10. leejor
    10,360
    226
    Forgot about this...In Settings/General/Global Options/System Wide Options, there is an option to allow calls to outside numbers from ring-groups. Did you have that checked? If not, try it and you can probably ignore the above post.
  11. muaddib32
    Oct 16, 2010
    68
    Thanks leejor. Yes, I already have that option checked. Makes no difference. But your suggestion of diverting to a dummy extension works perfectly. Thanks.
