Forward to outside number
Discussion in '3CX Phone System - General' started by kungmats, Mar 30, 2010.
  1. kungmats
    Mar 30, 2010
    6
    Hi!
    I resently set the 3CX system up and I think I got most things to work, except "Forward to outside number"
    The ring group rings, but when it comes to the forward part it stops and gives an error ring tone
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    For that you would need to enable the parameter located in:
    Settings > General > Global Options > Allow forwarding to external number from Ring Groups / Queues.
  3. kungmats
    Mar 30, 2010
    6
    Thanks, but that checkbox is already checked
  4. LeonidasG
    Nov 19, 2008
    1,406
    81
    If that's enabled then the error you are getting must be related to some other configurational issue.
  5. leejor
    10,371
    230
    Do you actually have a second line for the outgoing (transferred call) to use?
