forward to outside number
Discussion in '3CX Phone System - General' started by biker29r, Aug 28, 2011.
  1. biker29r
    Aug 23, 2011
    13
    Can "Forward ti an outside number" be populated by more then one number? if can- what is the syntax?
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    no it cannot. One number per field.
    Thanks,
    Nate
