Forward to Voilcemail
Discussion in '3CX Phone System - General' started by andew, Jan 21, 2009.
  1. andew
    Jul 2, 2007
    10
    We are setting up our 3cx and are loving it. But we have one problem.
    I want unanswered calls to go to voice mail. I have set a forward rule to forward unanswered calls, for all numbers, for all hours to voicemail for the extension that has been rung.
    eg:
    ext 206 - forward unanswered calls, all hours, all numbers, to voicemail, destination 206.
    if i ring 206 from anther extension 206 rings for about 60's then gives a beeping tone.
    if i set it to forward all calls, it works, if i set to forward on busy, it works, just not on no answer
    Any idea?
    3cx Version :7.0.4249.0
    we are using PSTN phones with Zoom VOIP ATA adapters.
    Also how do i backup the system settings, and then restore them?
    All help is gratefully recieved
    Toby
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    I suspect that the forward on no answer is hitting some ring timeout at telco level. Is it possible that the telco times out at or before 60 seconds?
    Try to set the forward on no answer to 15 or 30 seconds and see the outcome.
  3. andew
    Jul 2, 2007
    10
    I never did say thanks for this. it sorted out my problem :)
