Forward Voice Mail to a Queue
Discussion in '3CX Phone System - General' started by Cynthia Slade, May 31, 2012.
  1. Cynthia Slade
    Mar 22, 2012
    45
    Can I set up an extension that goes directly to voicemail and after a caller leaves a message it will forward the voicemail to a queue?
    Does anyone have this setup, or anything similar? Thank you
    10,365
    227
    If the caller presses * they will be sent to the operator extension. If you do not have an operator then is can be sent on to queue. I haven't tested to see if a message is retained, if the caller "jumps" off to the operator. You'd have to try it out. If it does work, you would have to inform the callers to press * at the end of their message.
    That is about the only place (at least, in version 10) that callers can go once landing in a voice mailbox.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    Previous reply seems misguided as it talks about leaving a mailbox instead of leaving a message. It sounds like you want to send the Voicemail to many recipients. I think you would have to use Send Voicemail to Email and create an Email Group with the Queue people in it.
  4. leejor
    10,365
    227
    Sorry, I saw Queue and thought "call Queue", they want to then send the caller into a Queue after leaving a message, for some reason.
  5. Cynthia Slade
    Mar 22, 2012
    45
    To clarify: The company would like to be able to have a caller to leave a message in the "emergency repair" mailbox and then have the 3CX system notify a call queue or group that a message is waiting. They do not want it sent by email - they want it sent by phone/msg.
  6. leejor
    10,365
    227
    Perhaps, something like....http://3cx.ideascale.com/a/dtd/Ring-Group-Department-mailbox/71758-9854
  7. craigreilly
    Feb 1, 2012
    2,962
    180
    lots of votes there. hopefully it will be transferred to the new system and considered by 3cx.
  8. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    This doesn't seem like any kind of a likely change since it would be a big modification of the voicemail system. You want someone to leave a voicemail, but you don't want it handled like a voicemail and you want voicemail notifications sent by phone which is also not something normal. I understand the use case but not sure how it would get implemented.
  9. craigreilly
    Feb 1, 2012
    2,962
    180
    I think he wants it to be distro'd to members of a queue - not really to the phone - but notify them with the BLF.
    And when they listen to the message via the system extension - have it say "Message for Call Queue xxxxx from ______ "
    I do not use call groups - but can see the need.
