Forwarding a call to dial another number
Discussion in '3CX Phone System - General' started by netmatika, Apr 17, 2007.
  1. netmatika
    Feb 16, 2007
    17
    Hi all,
    i'm testing 3CX system with very good result 8) with 3 PSTN lines on Grandstream GXW 4104, 3 extension with HandyTone Series - Analog Telephone Adaptors and 3 Voip Providers.
    i have a question:
    Can i forward an incoming call to another line registered on my 3CX and dial the final number?
    example:
    line 1 PSTN
    line 2 VOIP
    990 Extension digital receptionist
    i call my voip number on registered line 2 and answers my digital receptionist with extension 990...
    now my digital receptionist must ask me:"dial the final number!"...
    i digit the final number and the system routes the call on line 1.
    is it possible to goal this result?
    any idea?
    thanks in advance
    Best regards from Italy
    Netmatika
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,936
    250
    Hi Netmatika!
    Unfortunately this is currently not possible. You can forward calls to numbers on the PSTN, however they must be pre configured on the system. ...
  3. Anonymous
    Anonymous Guest
    To elaborate on what Nick said.
    Dialing the numbers is not possible (as yet :)) but you can forward the numbers using the IVR.
    You need to pre configure the numbers in the IVR first like
    Press 1 ---> [number]
    etc
    that can work, as long you have enough ports and not routing on the same incomming.
    But I am not sure if that is where you are after, but might be a good interim solution.
  4. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Nick,
    This would be a nice feature to add later (hopefully sooner).
  5. netmatika
    Feb 16, 2007
    17
    Forwarding calls
    Hi all,
    thanks all for your reply...
    waiting this feature in the nexts releases of 3CX i add my new test :)
    at my GXW 4104 on my 3rd port FXO i've registered extension 200 (for example) instead of a line...
    good result:
    on incoming call i forward to extension 200 and i hear newly free line(3rd FXO port) :)
    bad result:
    i can't insert this line in outbound rules :(
    thank you
    Netmatika
