Forwarding extension to cellphone, but only one way sound.
Discussion in '3CX Phone System - General' started by ackrts, Feb 7, 2008.
  1. ackrts
    Feb 5, 2008
    7
    Great system, still setting it up for the first time. Thanks for everyone's work!!
    I have an internal extension setup that callers can press 0 to transfer to a cell phone (urgent calls) or leave a message in the voice mailbox. Everything works fine for the transfer, but after 3CX transfers the callers, they cannot hear the person on the cell phone. Cell phone user can hear the caller, but cannot respond. Probably a port issue on the Linksys firewall.
    I have to following ports forwarded to the 3CX server on the firewall;
    9000 - 9015 TCP/UDP External calls
    5060 - 5060 TCP/UDP SIP for external ext. future use.
    1000 - 2000 TCP/UDP (tried with and without) RTP
    3478 - 3478 TCP/UDP Stun
    Am I missing any ports that may be affecting these calls? Is there something else I am not thinking of? If I change the cell phone to a callcentric sip account on a soft phone it seems to work, however that softphone sits on a computer on the network - not really hitting the firewall.
    Any suggestions would be greatly appreciated!
    Thanks.
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    What if you call the cell phone directly from an extension. Does that work?
  3. ackrts
    Feb 5, 2008
    7
    Thank you for your reply. Yes, if I call the cell phone directly from an internal extension it seems to work fine - audio is good both ways. It is something in the call forwarding. Even if I change the extension from forwarding to a cell phone to a regular land line, I get the same results so I know it has nothing to do with the cell phone itself. If the call is transfered I get one way audio.
    Thanks for any suggestions!
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Piece of logs may shed some light. Peoples often underestimate the power of status screen...
  5. ackrts
    Feb 5, 2008
    7
    Update... The problem was with the VOIP provider, Callcentric. They do not support call transfers. Switched to another provider and the call transfer worked properly. Hopefully Callcentric will be able to work with the 3CX for transfers later.
