Forwarding Incoming Calls
Discussion in 'Windows' started by 10m, Mar 30, 2015.
  1. 10m
    10m
    May 3, 2014
    26
    7
    Good day Guys.
    I have got a GoIP (GSM gateway) connected to my network to allow me make outgoing calls and receive calls from outside. I want the gateway to forward the ID of the caller to the 3CX server so they can be identified using the company phone book. My challenge is I keep getting this error :
    30-Mar-2015 13:02:43.922 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from xxx.xxx.xxx.7:5060 tid=971824389 Call-ID=1757903766@xxx.xxx.xxx.7:
    I've tried fiddling with the outbound parameters but I am not making any headway.
    In the body of the error I see that the ID of the caller is in the log, but the call will not go through.
    On the same gateway though, I am able to make outgoing calls.
    Any help?
    Thank you
    10,583
    251
    To clarify....You cannot receive any incoming calls as a result of what ever is causing the error log? Or you do get calls, just no Caller ID?
    As you've hidden the IP, I cannot tell if it is a public IP, or a local IP (locals IP's don't need to be concealed).
  3. 10m
    10m
    May 3, 2014
    26
    7
    Thanks for your response Leejor.
    The device (ie the GSM gateway) allows you to forward the ID of the caller to 3CX. When this feature is set, I get the error and what characterizes the error is that the 3CX PBX can make a call out on the device but cannot receive a call. That is when I get the error.
    The full error log is displayed below
    30-Mar-2015 13:02:43.922 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 172.20.11.7:5060 tid=971824389 Call-ID=1757903766@172.20.11.7:
    INVITE sip:1001@172.20.11.2:5060;transport=udp SIP/2.0
    Via: SIP/2.0/UDP 172.20.11.7:5060;rport=5060;branch=z9hG4bK971824389
    Max-Forwards: 30
    Contact: <sip:0803401xxxx@172.20.11.7:5060>
    To: <sip:1001@172.20.11.2:5060>
    From: "0803401xxxx"<sip:0803401xxxx@172.20.11.2:5060>;tag=974495270
    Call-ID: 1757903766@172.20.11.7
    CSeq: 3 INVITE
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REFER, REGISTER, MESSAGE, INFO, SUBSCRIBE
    Content-Type: application/sdp
    Proxy-Authorization: Digest username="90001",realm="3CXPhoneSystem",nonce="414d535c0b29cc6317:86aa1f68329d97301e2666cc2cbca1fe",uri="sip:1001@172.20.11.2",response="6ffdfd3f2a84415819694a8e787572d1",algorithm=MD5
    User-Agent: dble
    Content-Length: 280
    Remote-Party-ID: "0803401xxxx" <sip:0803401xxxx@172.20.11.2>;party=calling;screen=no;privacy=off
    v=0
    o=dble 1427717036 1427717036 IN IP4 172.20.11.7
    s=dble
    c=IN IP4 172.20.11.7
    t=0 0
    m=audio 16384 RTP/AVP 8 0 18 4 101
    a=rtpmap:8 PCMA/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:18 G729/8000
    a=rtpmap:4 G723/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    a=ptime:20
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    Thank you
  4. 10m
    10m
    May 3, 2014
    26
    7
    Hi Everyone.
    I have got my problem solved. It all was in the GoIP. I had to make a few configuration changes to the device as seen in the screenshot attached.
    Once I did this, there were no errors and the caller IDs were transferred from the device to the 3CX PBX and they were matched against entries in the company phonebook and Viola,..... Caller ID Displayed.
    Thanks.
  5. leejor
    10,583
    251
    When creating trunk groups in 3CX, they usually start with 10000 and count up. I see you have the gateway as 90001. Does that match the trunk number in the PBX? You also appear to be sending the call to 1001, is that supposed to be a trunk group (missing a digit), or an extension number?
  6. 10m
    10m
    May 3, 2014
    26
    7
    Hi Leejor.
    90001 is the virtual extension number that was assigned the gateway by 3CX. It should have been 10000 but when I installed v12.5 I noticed that it was assigned 90001. I think the problem was in the configuration of the GoIP, when the CID forward mode was set to Remote Party ID, it worked with the extension 1001. When I set the CID Forward Mode to Use CID as SIP Caller ID, it resulted in the authentication error. Setting the Forward Number (PSTN to VoIP) as the virtual number of the gateway corrected the authentication issue.
    I got the idea after reading a post relating to the same problem but the poster had issues with a Polycom Soundstation.
  7. leejor
    10,583
    251
    So...you got it working?
  8. 10m
    10m
    May 3, 2014
    26
    7
    Yes I did.
