OutBound:
Trunk:
SIPGate.de is set up for testing, and is only used for that. Please ignore
02-Mai-2016 09:34:50.077 Leg L:428.2[Extn] is terminated: Cause: 408 Request Timeout/INVITE from local
02-Mai-2016 09:34:23.229 Leg L:428.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
02-Mai-2016 09:34:23.077 L:428.1[Line:10001<<0987654321] forwards call from Extn:250 to Out#:>>Rule{Regel Vodafone 7090}>>0123456781 based on rule Fwd[Available/NoAnsw]
02-Mai-2016 09:34:23.077 L:428.1[Line:10001<<0987654321] failed to reach Extn:250, reason No Answer
02-Mai-2016 09:34:18.037 [CM503025]: Call(C:428): Calling T:Extn:250@[Dev:sip:
[email protected]:64808;rinstance=0-befa1e674f734c5fbf56a03edd2a0bb5;ob,Dev:sip:
[email protected]:5488;rinstance=a376156d3ffcd389] for L:428.1[Line:10001<<0987654321]
02-Mai-2016 09:34:18.034 [CM503025]: Call(C:428): Calling T:Extn:250@[Dev:sip:
02-Mai-2016 09:34:17.989 [CM503027]: Call(C:428): From: Line:10001<<0987654321 ("0987654321" <sip:
[email protected]:5060>) to T:Extn:250@[Dev:sip:
02-Mai-2016 09:34:17.989 [CM503004]: Call(C:428): Route 1: from L:428.1[Line:10001<<0987654321] to T:Extn:250@[Dev:sip:
I had to sequester a few fields:
-> xyz.aaa.de is the domain which is publicly accessible. I need you mask, sorry
-> 172.16.0.56 is the local IP of the PC, which does not decrease but phone
-> 250 is the internal extension, Outcall ID but in profile the 03 at the end
-> 0123456781 is the phone number, which should be called with the forwarding
-> 0987654321 is the number which is calling me
Trunk Details:
