Forwarding Rules Wildcard
Discussion in '3CX Phone System - General' started by Eric Nush, Feb 13, 2017.
  1. Eric Nush
    Feb 13, 2017
    6
    I would like to add a Forwarding Rule > Exception that includes a wildcard for any outside line. How would I do this? I can get * to block all calls, or areacode* to block that area code, but how would I do it for any outside call? I am using 4 digit extensions, is there a wild card for anything longer than four digits? Thanks!
    11,113
    329
    Under the forwarding rules for each extension, you should see a check box different behaviour for internal calls, tick that and additional options pop up.
