Forwarding rules
Discussion in '3CX Phone System - General' started by Archie Frederic, Oct 10, 2017.
  1. Archie Frederic
    Jan 31, 2017
    72
    Hi guys!
    Just wanna ask if you have any idea of what could be the problem when all local calls to any other extensions are being forwarded to a single extension? I checked the forwarding rules of these extensions but I did not see anything suspicious. I checked the phone status and they are available. The only suspicious thing that I've seen was the unsupported firmware. But I don't think that was the issue. By the way, the phones are T19. Thanks.
  2. StefanW
    Jun 2, 2009
    1,210
    85
    The MMC only shows Green for been registered but not the profile status of the extensions it self.
    May they are all set to DnD and then the "Busy" frwd to the mentioned extension...
  3. Archie Frederic
    Jan 31, 2017
    72
    I also noted those things during the troubleshooting. The thing is, why would it forward to only one specific extension when on their forwarding rules, it was set to go to their voicemail? I did not see any forwarding rules that would forward it to that specific extension.
  4. leejor
    10,585
    252
    Check the 3CX Activity Log.
