Forwarding to mobile
Discussion in '3CX Phone System - General' started by Hjalmar, Jan 26, 2009.
  1. Hjalmar
    Aug 6, 2007
    5
    Hello all,
    I have a question about redirecting to an mobile number:
    How can you create this? If I try it I get Reason: Not registered (dummy extension).
  2. islander
    Jan 15, 2009
    7
    Create a "Forwarding rule" to external number maybe Second page in edit extensions
    I have ring group if not answered in XX sec then it dials my mobile..
