Solved FQDN and IP Address
Discussion in '3CX Phone System - General' started by benratty, May 12, 2017.
  1. benratty
    May 23, 2011
    74
    I recently ran an update on a my PBX v15 and after the first couple of updates the IP address registered to the 3cx FQDN has changed. This PBX had previously been moved between sites and after upgrading it to v15 we registered the 3cx domain we had on it to the new IP address, after these updates though it has reverted back to its original IP address.
    I have tried logging into the partner portal but it only lets you release the FQDN and not change the IP address, how can I get the IP address corrected back to the correct one?
    11,123
    330
  3. benratty
    May 23, 2011
    74
    No this just explains changing the external IP in 3CX, the external IP in 3CX is correct. Its the .3cx.co.uk domain we have registered that has gone back to a previous IP address.
  4. leejor
    11,123
    330
  5. andreaschr
    Oct 26, 2015
    91
    6
    Hi benratty,
    Do you use Static or dynamic ip in the configuration of the PBX?
  6. benratty
    May 23, 2011
    74
    Its a fixed IP address, however after going into the management console and keying the IP address back in again it later then picked up the correct IP address when resolving the URL so it is working again now. I had to just key the external IP address in again even though it was same one and already there.
    Working again now though. Thanks
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,443
    540
    Glad to hear the issue is resolved. Please keep an eye on it and let us know if something changes
