Solved FQDN does not resolve
Discussion in '3CX Phone System - General' started by MarPyt, Jan 16, 2018.
  1. MarPyt
    Feb 7, 2015
    12
    My FQDN does not resolve correctly when trying to reach PBX Console on a Cloud.
    When typing ...3cx... (fqdn) it comes back as "unreachable"
    Only direct ip address works.
    In User portal everything is correct.
    Why so?
    11,079
    324
  3. MarPyt
    Feb 7, 2015
    12
    I followed, changed ip to dynamic, restarted services, changed to static and re-started service again.
    Operations acknowledged by 3cx.net via email.
    I have been waiting several hours now, getting "unable to connect" message.
    Will give it a day or so, meanwhile thanks for pointing it out.
  4. leejor
    11,079
    324
    If you do a tracert, in Windows, from a PC on another network altogether, does it show the correct IP? Does it show any IP?
  5. MarPyt
    Feb 7, 2015
    12
    Yes , I did nslookup from debian server as well as from different computer on different network and it
    shows ip belonging to FQDN and vice versa, It shows on 3cx customer portal as well. I will wait maybe an update is taking longer.. thanks for your interest, appreciate it
  6. leejor
    11,079
    324
    So...it shows, what IP, associated with your FQDN, an old one, one that you've never seen before? Was you public IP ever changed since the original installation?
    Since you say that direct IP works, I assume that the FQDN is not resolving to the same IP.
    MarPyt likes this.
  7. MarPyt
    Feb 7, 2015
    12
    It shows correct IP. Now I tried from yet another computer and it works. But on original machine it still does not resolve. Cleared cache etc, using different browsers does not get me anywhere, only bu direct ip address, Any thoughts?
  8. BrenttG
    BrenttG New Member
    Nov 17, 2017
    114
    31
    Check the hosts file if its a windows pc, see if some other person hard coded the entry....
    And where does that PC get its DNS from, is this different from one that works.
    YiannisH_3CX and MarPyt like this.
  9. MarPyt
    Feb 7, 2015
    12
    Host file 2 entries for local host, 2 different fqdn's assigned to the same local host
  10. MarPyt
    Feb 7, 2015
    12
    Deleted both entries from hosts file and now..it works.
    Possibly during original installation 3CX wrote to hosts file and it just stayed there.
    Nevertheless I am good to go and YOUR help is really appreciated. 3CX re seller could never think of that...
  11. BrenttG
    BrenttG New Member
    Nov 17, 2017
    114
    31
    Your welcome, a proper reseller, should have easily solved this.
    Someone should mark this as solved.
  12. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,334
    533
    Glad to see that issue has been resolved. Marking this as solved.
