FQDN key binding "Domain Suffix '3cx.us' Exhausted"
Discussion in '3CX Phone System - General' started by Platonik, Jul 4, 2017.
  1. Platonik
    Dec 29, 2016
    9
    After following the procedure to upgrade a production system with 32 SC from a trial license we hit a huge wall. Since the FQDN are bound to licenses as per https://www.3cx.com/docs/key-already-bound/ we needed to release the FQDN from the trial key before we could restore from backup. Upon restoration and after release of the key, the FQDN gave us the following ''Domain Suffix '3cx.us' Exhausted".
    We need immediate support to solve this FQDN issue that we do not have control over as this is a production system that serving over 65 extensions.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,455
    541
    Hello @Platonik,
    Please note that the correct procedure to upgrade a licence key is to upgrade the key already installed in the system without needing to un-install and re-install. Unfortunately there is no way to re-claim that FQDN and you will need to choose a different one.
    The phones will need to be re-provisioned if they were provisioned as remote extensions using the 3cx.us FQDN.
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    You were running 65 extensions with the free trial of 3cx ?!?!?
