FQDN Question?
Discussion in '3CX Phone System - General' started by WINWARE, Dec 14, 2007.
  1. WINWARE
    Nov 30, 2007
    29
    Can someone explain this example used during the Version 5 install:
    "For example, If your phone system is called sipserver.mydomain.com, then both sipserver.mydomain.com and mydomain.com will suffice,
    Ths value is not relevant if you specify the IP of the server in the phone
    configuration."
    My question is:
    If I use our FQDN by creating a A Record in our DNS for sipserver.mydomain.com, does that mean that I must change our root domain to also point to the Phone System? How will the mydomain.com suffice if I don't? This is not possible if this is the case since our root FQDN points to our webservers. Am I reading this right?
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    I assume the FQDN including the nodename would be what you should use in that instance then. It may be that the lookup reverts back up the tree until it finds a valid A-record?
