FQDN settings
Discussion in '3CX Phone System - General' started by DMarriott, Jan 23, 2014.
  1. DMarriott
    Jan 23, 2014
    10
    I setup 3CX for the first time yesterday however I unfortunately entered the incorrect details during the initial setup for the two FQDN addresses. How do I get back to those settings to fix the mistake? I have gone through all the pages in the web gui trying to find these settings but haven't seen them anywhere. Do I need to run the setup again?
    Cheers,
    Dave
    10,582
    249
    If you are talking about setting the Domain Name. It is in there under Advanced settings alongside the ability to allow Direct SIP calls. There is also a table of almost all settings, allowing you to customize them as needed, use with caution.
  3. DMarriott
    Jan 23, 2014
    10
    I did see a field called "LDAP Server (FQDN)" however the field is blank. During the initial setup, I did have to enter 2 address's titled "Internal FQDN" and "External FQDN". I haven't seen these particular entries anywhere in the settings. I'm not sure where to find them in order to fix the wrong entries I had put in.
  4. leejor
    10,582
    249
    Under Settings/Advanced?settings for Direct SIP calls, is where you enter your domain name. This is use if you have a domain name or use a Dynamic DNS service, and your remote sets will be using it to contact the 3CX server.
    Under Settings/Advanced/ Custom parameters, you cab see just about every setting.
  5. mlump
    mlump New Member
    Feb 24, 2012
    113
    DMarriott,
    The only place you can change the Internal and External Domain names for the HTTPS SSL settings used by the 3CXPhone software is during the install. This is something i have spoken to 3CX about and they are working on correcting. However for now you will need perform a full back of 3CX using the backup and restore tool. Uninstall 3CX then reinstall with the corrected settings. Once you get to the setup wizard you will select restore existing PBX and point it to your backup. Once done you should be good to go.
    What leejor is referring to is the SIP Domain name used in direct SIP calls.
  6. DMarriott
    Jan 23, 2014
    10
    thanks mlump, I was thinking that a fresh install was the only way to go. Thanks for confirming it for me.
