Solved FQDN to Wrong IP after testing
Discussion in '3CX Phone System - General' started by Username, Oct 24, 2017.
  1. Username
    Jul 13, 2017
    6
    Hi everybody.
    I had some tests with a second testing PBX. My 3cx FQDN has updatet to my testing server IP Adress.
    if i log me in to the customer portal, i can see the wrong IP (Testserver).
    How can i change that urgently?
    Michael
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @Username
    Please note that you should not use the same licence key to run tests as this will cause problem with your production installation. It could also lock your key as you may hit your maximum activation limit and then non of the installations will work.
    To get the IP to update to the production PBX you need to shut down the test PBX, then navigate to the settings / network of the production PBX and set the IP to dynamic. Restart all services. This will update the IP but note that there is a TTL depending on your licence type and it could take some time until the DNS propagation reaches you.
  3. Username
    Jul 13, 2017
    6
    Great, thanks!
