FQDN vs IP address when registering / making calls
Discussion in '3CX Phone System - General' started by shedster99, Jan 31, 2011.
  1. shedster99
    Aug 3, 2009
    28
    I have a very, very odd issue.
    Using v9 (free version) I can create a single extension and either using a soft/hard phone if I use a fqdn to register the extension with the PBX (registration is 100% successful) I cannot even make the simplest of internal calls to *777 or the voicemail extension (900).
    If however I set the extension (soft/hard phone) to use the IP address of the PBX, it works sweet as a nut.
    The PBX is on a server on the net with a public IP address
    FQDN resolves to same IP address as the working environment
    Handset and softphone are on public IP addresses in local LAN so are remote extensions
    Any ideas ?
    The only difference between working and not working is the IP address vrs the FQDN ?
    Log of INVITE below, i have replaced the IP address and fqdn for security ;
    14:51:20.354 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:*777@fqdn_address:5060 SIP/2.0
    Via: SIP/2.0/UDP IP_ADDRESS:5060;branch=z9hG4bKef755824a875047ec
    Max-Forwards: 70
    Contact: "101"<sip:101@IP_ADDRESS:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-1000-8000-00085D18D6BB>"
    To: "*777"<sip:*777@fqdn_address:5060>
    From: "101"<sip:101@fqdn_address:5060>;tag=be59ac12bf
    Call-ID: a15215b7fc9ad742
    CSeq: 8147 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, UPDATE, PRACK, SUBSCRIBE, INFO
    Supported: gruu, path, timer, 100rel, replaces
    User-Agent: Aastra 53i/2.5.1.2000
    Allow-Events: talk, hold, conference, LocalModeStatus
    Content-Length: 0
    10,853
    299
    Did you put your FQDN info into 3CX, in....Settings/Advanced/Local SIP Domain ?
  3. Lukas
    Jan 23, 2011
    45
    Right... it took me 2 hours to figure out... and only with the help of the forum... maybe it could be spelled out more explicitly in the manual, as it looks like I am not the only one.
    Of course, the real problem is that we don't read manuals -- do we? :oops: If I think back at this, it would have taken less time to RTFM from top to bottom :lol:
  4. leejor
    10,853
    299
    Yes, well, with more and more "consumer products" working right out of the box, fewer people can be bothered reading the manual.
  5. shedster99
    Aug 3, 2009
    28
    DOOOOOOOHHHHHHH !
    No, it was the IP address.... :oops: :oops: :oops:
