Free 3cx phone system
Discussion in 'Windows' started by cg12510, Sep 1, 2010.
  1. cg12510
    Sep 1, 2010
    9
    All, we downloaded the free system from 3CX today.
    I have a question in the management console
    under settings
    network
    3cxtunnel
    ip (how do you change this address??? the address on the system is 192.168.1.6 we do not have this address on our server.) can you change it??
    any idea how to change it??
    thanks in advance
    10,766
    286
    That was the IP on the computer at the time you installed 3CX. Check the PC network settings, what IP does the PC currently show? You should be using a fixed IP on a 3CX server, you don't want that changing as all of your devices will be pointed to that IP.
